You have the option to clear MACsec statistics for all ports, or clear MACsec statistics for a specific port. Clearing MACsec statistics can be useful for debugging purposes.
    enable
    configure terminal
  2. Clear all MACsec statistics:
    macsec clear-stats
  3. Optional: Clear MACsec statistics for a specific port:
    macsec clear-stats port {slot/port[/sub-port][-slot/port[/sub-port]][,...][slot/all][all]}
Switch:1>enable
Switch:1#configure terminal
Enter configuration commands, one per line.  End with CNTL/Z.
Switch:1(config)#macsec clear-stats
Switch:1>enable
Switch:1(config)#macsec clear-stats port 1/3
Use the data in the following table to use the clear macsec-stats command.
Variable Value
Identifies the slot and port in one of the following formats:
  • a single slot and port (slot/port)
  • a range of slots and ports (slot/port-slot/port)
  • a series of slots and ports (slot/port,slot/port,slot/port)
  • all ports on the same slot (slot/all)
  • all ports on the switch (all)
